Headlight troubles.
Old Nov 3, 2005 | 02:14 AM
miked's Avatar
Default Headlight troubles.
I don't know what the deal is with my headlights. The drivers side low-beam bulb was just replaced about 2 weeks ago, and what do you know... yesterday when i started my car the same light was out. I put my high-beams and fogs on and when I turned those off, my light was working again. This process occured a few times as I went from place to place. Now the light is completely out, no matter what I do. I checked all my connections and am about to switch bulbs with the passenger side to see if that helps. What are the chances the bulb is just blown again? (Doesn't look like it.) Any possible electronic explanations for my troubles? I'm going to Ach-Tuning for stealth corner bulbs so if I don't get this figured out here I'll talk to them about it. Thanks.
Old Nov 3, 2005 | 11:05 AM
Jestnomen's Avatar
6th Gear
Default RE: Headlight troubles.
Well if the bulb isn't broken, then i'd say it's your headlight stalk. They go bad all the time.
Old Nov 3, 2005 | 12:01 PM
CRAZYHAWK's Avatar
Try spraying the stalk with Radio Shack Contact Cleaner.
elizedge
Sep 12, 2013 11:48 PM
jzhcky10
Jul 1, 2009 10:53 PM
euro_2nr
Mar 3, 2008 10:05 AM
euro_2nr
Feb 22, 2008 01:07 PM
alfiesride
Mar 5, 2007 01:01 AM
