headlight washer jets question?
Old Dec 13, 2007 | 09:51 PM
spectrum's Avatar
Default headlight washer jets question?
would anyone know why the headlight washer jets stop working and windshield washer continue to work? This has happened to me and for the last month been in Florida not a freeze issue.
Old Dec 13, 2007 | 09:55 PM
ImTheDevil's Avatar
Default RE: headlight washer jets question?
Maybe a pressure hose popped off and stopped feeding pressure to the pump? Take a look inside the bumper and see if you see anything loose or disconnected around the headlight washer assemblies. Chances are you'll find something.
Old Dec 13, 2007 | 10:05 PM
spectrum's Avatar
I'll have to check that out tomorrow. Is that visible once the lower shield is off?
thanks for the fast reply
Old Dec 13, 2007 | 10:45 PM
ucla86's Avatar
ORIGINAL: spectrum
I'll ask the obvious: Is your washer fluid low? It sprays only the windshield when it's low. (Also, the headlights have to be on to get sprayed.)
Old Dec 13, 2007 | 11:05 PM
spectrum's Avatar
washer fluid not low and lights on I made several trys tonight with no luck but a clean window!
Old Dec 13, 2007 | 11:17 PM
ucla86's Avatar
ORIGINAL: spectrum
Yeah, I'll bet...
Here's another thread that says the headlight washers have a separate pump from the windshield washers.
https://www.audiforums.com/m_736634/tm.htm
Old Dec 13, 2007 | 11:36 PM
SAudi's Avatar
are you saying that the headlight washer come on for a few seconds and then go off, if so this is normal, the headlights go on for only a few seconds to get grime off.
Old Dec 14, 2007 | 01:33 AM
01A4T's Avatar
ORIGINAL: SAudi
+1,000
If the headlight washers diddn't go off after a few seconds, you would have to refill your fluid every time you used your wiper washer things.
Old Dec 14, 2007 | 11:57 AM
ucla86's Avatar
ORIGINAL: spectrum
ORIGINAL: SAudi
Good catch: The headlight washers only fire one short burst each time you pull the lever. I didn't think to mention that.
Old Dec 14, 2007 | 12:08 PM
1Move's Avatar
ORIGINAL: ucla86
ORIGINAL: spectrum
ORIGINAL: SAudi
Good catch: The headlight washers only fire one short burst each time you pull &HOLDthe lever for a few seconds. I didn't think to mention that.
