HELP ME PLEASE!!!
Old Aug 2, 2006 | 04:33 PM
klum00's Avatar
Default HELP ME PLEASE!!!
F_CK, F_CK, F_CK.... so i take the camshaft holding tool off so i can put the new timing belt on. as i go to put it on, and im not really pulling too hard, the left camshaft all of a sudden rotates maybe 50 degrees clockwise. so now the two camshafts are not in the same position, one has rotated more than the other. i have a feeling im completely screwed here, what do i do/can i do??
Old Aug 2, 2006 | 04:39 PM
techbod's Avatar
Default RE: HELP ME PLEASE!!!
reset the cams then put the tool back on to ensure its lined up and fit the belt ( don't remove the tool till the belt is fitted and tensioned) then 2 rotations to make sure the lines still line up and a final check if the tension need adjusting
your not the first person to do that
Old Aug 2, 2006 | 04:43 PM
onepoint8tee's Avatar
Oh man your engine is fucked... Time for a new car.
jk... Are there TDC marks on the cam/engine block??
Old Aug 2, 2006 | 04:53 PM
klum00's Avatar
yeah i used a straight edge and marked TDC markes so i know where the cams need to be. so should i just rotate the one on the left so it is lined up and then start over?? because right now the two are like 50 degrees off from each other.
Old Aug 2, 2006 | 04:55 PM
ORIGINAL: klum00
rotate twice i think.
acetrebo's Avatar
You know,
I hate to say this, but I told you yesterday about 5 times to mark the cams in case they move.
Sounds like you did not mark the cams.
look for the stock cam markings and line everything up to top dead center. Your manual should have pretty in depth info on how to find TDC and line everything up.
Good luck.
Old Aug 2, 2006 | 05:02 PM
techbod's Avatar
if im right the bolts on the pulleys to the cams have to line up with the bulge center facing each other that's how they line up, the cam bolts have a lobe on them.
0- -0
Old Aug 2, 2006 | 05:13 PM
klum00's Avatar
ok so i took a picture so maybe it can help me/you out. see how the left pulley is turned more than the right? thats what turned how do i get just the one camshaft too rotate without the other?
[IMG]local://upfiles/9590/B9DEACCF34B34FB997D5B336FC55817A.jpg[/IMG]
Old Aug 2, 2006 | 05:15 PM
klum00's Avatar
basically im not sure exactly how to reset the cams...
Old Aug 2, 2006 | 05:36 PM
acetrebo's Avatar
Looks like you got the fan of, good job.
I am sorry I dont know the details of the 2.8 TB change. I had similar issues on my 1.8, because my belt I think jumped a tooth or two when the tensioner broke.
My advice would be to get either a haynes manual or bently manual on the car. It has instructions on how to line everything up.
Mine had a mark on the engine block behind the top cam to line up Top Dead center. Then, then was a mark on the dampner pulley that lined up with a mark on the t-belt cover for the alignment of the crankshaft.
I used these marks to make sure everything was lined up before putting the belt on.
I am sure yours is a similar process, but for $15 a haynes manual is an invaluable tool to have at your disposal.
I am sure someone whos has done this will chime in and tell you where the marks are for the cams and crankshaft. I think Dave already mentioned the marks for the top cams, but you may want to check the crankshaft alignment as well to make sure all is good.
