Help! Oil cooler coolant line leaks, Tried new clamps, don't stop
Old Nov 9, 2005 | 01:42 AM
auto3251's Avatar
Default Help! Oil cooler coolant line leaks, Tried new clamps, don't stop
Okay, 1998 audi a4 4wd, 2.8 v6 model (not the "all the room in the world" 4banger)
The coolant line leaks where it meets the oil cooler. I've tried putting new clamps on them, the screw type clamps you get at autozone/homedepot, they should seal stronger then the spring type ones. After 3hours I got the old clamps off and lines off cooler, another 2hours I get the new clamps tightened on the lines. Pour in water, and it leaks 10times as fast now, a nice fast drip to a thin stream.
I have seen the DIY on it, and it looks so dang easy, because it's on a 4banger, but on a v6 it's in such a tight sqeeze! I had to remove my oil filter to get just a tiny bit of extra space, which made me do a oil change, then one of the stupid lines was only 2inchs long!!! 2inchs plus it makes a 90degrees turn!!! I don't know how on earth you guys with a v6 do it, there is like no room at all!
I'm giving up on this unless someone has a quick and easy DIY for a V6 version.
I'm at the give up point, and want to know how much would a normal shop charge to fix this? They will probably have to replace the lines maybe, since they probably are kind of beat up, and new clamps ofcourse, and a complete coolant flush. Hoping this isn't going to be one of those bend over and get ready for 500dollars!
Old Nov 9, 2005 | 03:08 AM
auto3251's Avatar
Default RE: Help! Oil cooler coolant line leaks, Tried new clamps, don't stop
Also, just thought about removing the oil cooler. How hard is it to remove the oil filter, and will standard heaterhose line from home depot work as a replacement for the hose?
Old Nov 9, 2005 | 03:59 AM
trailboss's Avatar
Was the ports on the oil cooler where the hoses went onto all caked with dried up coolant? If so did you clean it off, when i did mine there was a total build up of crap there and the seal would not have been good which is why it probablly started leaking in the first place. I cleaned the ports with a battery terminal cleaner the wire one, wire brush and a dremel with a little wire wheel to get all the stuburn spots.
Old Nov 9, 2005 | 04:33 AM
auto3251's Avatar
yeah, that was probably the problem, but there's no way I can actually clean it , there's no room what so ever, plus I think i beated up the short 2inch hose a bit to much. The only way I can see myself doing this is if I take off the oil cooler, is this hard?
If so, my only choice is to bring it to a shop, how much do you think a shop will charge to fix it?
Old Nov 9, 2005 | 05:41 PM
auto3251's Avatar
up need help bad
Old Nov 10, 2005 | 02:07 AM
auto3251's Avatar
someone must know
Old Nov 10, 2005 | 02:30 AM
dankhound's Avatar
The oil cooler is easy to remove from the block. When you take off the oil filter there is a big 24mm nut there. Remove that nut and the oil cooler slides right off. Replace the o ring on the back of the cooler to be safe.
Old Nov 10, 2005 | 07:18 AM
auto3251's Avatar
ORIGINAL: dankhound
I don't think my oil cooler even connects to my block, it connects to the oil pan. Anywho, where do I get the o-ring.
Also, can I just go get heater hose from homedepot to replace the coolant line that is about 2inches? Also what size is the hose, 3/8inch?
2008 Audi A4 S Line
Oct 11, 2012 07:35 AM
4mymalamute
Dec 24, 2009 11:08 AM
natefanaro
Mar 29, 2008 12:23 AM
99A4NOW
Jul 1, 2007 04:33 PM
quattromond
Jul 27, 2006 11:29 AM
