Help with rods
Old Aug 10, 2006 | 05:28 PM
Adam@mvp's Avatar
Default Help with rods
Im looking to do internals and iv noticed on the forums that there is alot of factors with rods and size of them and not alot of ppl make the rods
who should i go with since im getting JE pistons and rings
2001 Audi 1.8L T
Old Aug 10, 2006 | 05:44 PM
InsaneHatter's Avatar
Default RE: Help with rods
SCAT rods, cheap, powerfull, and will not break up to 500hp+
Old Aug 10, 2006 | 05:47 PM
Adam@mvp's Avatar
yes i seen someone mention that name but i wasnt for sure..
Is that like the main brand everyone goes for cause im not worried about cheap i just want quality and want to do it right.
Thanks for the info.
Old Aug 10, 2006 | 06:10 PM
when I say "cheap" dont get me wrong, scat rods are very good quality. they are just less expensive.
There is a 1.8T w/ a GT3076R on AZ using stock pistons and SCAT rods, and he is doing just fine (that setup should be able to run 320WHP+ on pump gas, which is around 410 crank HP)
There is also Pauter and Eurospec rods, but they are 600-800$ a set, compared to SCAT which is 300$ or so a set... and they around the same quality.
May I ask what you are upgrading too?
Old Aug 10, 2006 | 07:19 PM
Adam@mvp's Avatar
probably a GT2871R turbo and 440cc injectors.
can you link me to scats website or give me a part number for the rods you are talking about that would be very helpful
thank you
playboy00786
Jan 23, 2011 09:01 AM
Dirtbmxer2690
Jun 9, 2007 12:52 AM
voytas
Mar 29, 2007 03:17 PM
gododgers05
Mar 21, 2007 04:36 PM
johnstef
Mar 11, 2007 09:19 PM
