What's going on with these tie rods? Help Please!!
Old Mar 15, 2007 | 06:49 AM
gododgers05's Avatar
Default What's going on with these tie rods? Help Please!!
OK i drive a 97 a4q and i feltmy suspension being a lil rough, so itook a look at it and found out that the tie rod ends were really damaged, so i decided to replace them...i just finished putting the new ones on and the ride feels a little bit better, but im having trouble when turning...the steering gets stuck(the steering wheel does not come back to its normal position) when i do a slow turn, i noticed that the bearing in the new tie rods was hard to move but i have never done this job before so i figured it was normal...is it normal? will the bearing loosen up once it has been used for a while, or are these tie rod ends defective?
Thanks for the help in advance!
Old Mar 15, 2007 | 06:00 PM
CRAZYHAWK's Avatar
Default RE: What's going on with these tie rods? Help Please!!
You probably need a wheel alignment.
Old Mar 15, 2007 | 06:31 PM
yeah i know i need an alignment for sure...but are new tie rods that stiff? i mean the ones i took off were ridiculously loose, and the new ones i just installed made me turn red just to budge the bearing a little.
Old Mar 17, 2007 | 03:50 PM
CRAZYHAWK's Avatar
For a good front end shop:
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Old Mar 20, 2007 | 11:32 PM
JETSPEED333's Avatar
SoCal Crew Member
yes. the new bearing will feel pretty stiff.... that is normal
Old Mar 21, 2007 | 02:44 PM
2k S4's Avatar
There suppose to be tight!
You don't have any front toe in, that's why the wheel isn't going back to center.
Old Mar 21, 2007 | 04:36 PM
Thanks guys for the feedback...yeah imma fix that toe in problem with the alignment, im just gonna wait to install my new control arms.
playboy00786
Jan 23, 2011 09:01 AM
driftking8732
Apr 7, 2008 09:58 PM
Dirtbmxer2690
Jun 9, 2007 12:52 AM
voytas
Mar 29, 2007 03:17 PM
johnstef
Mar 11, 2007 09:19 PM
