Help Running Cables
Old Nov 10, 2005 | 05:29 PM
PhoneixFire13's Avatar
Default Help Running Cables
Hey all, I'm doing something nuts I think... I need to run 3x rca cables and a hefty power line through the interior of my 4d 1996 A4. Does anyone have any really good ideas on how to run them incognito or hide them underneath inside "coverings"? I need a direction to go and some help on how to get this done! Thanks!!! PF PS... it looks like the foot board molding is super tight... so that doesn't look fun. Thanks, PF
Old Nov 10, 2005 | 07:07 PM
dankhound's Avatar
Default RE: Help Running Cables
I would remove the kick panel molding and run them under the carpet. Your right, those can be on extreamely tight. They have these metal clips that clip into the body. They will pull out, but to be safe i would use a long screwdriver or prybar to pry them out.
Old Nov 10, 2005 | 07:54 PM
Ok, so if i attempt this... do i need to worry about the seatbelts? and to get the kickplate off... i just put a screwdriver in and torque? Really? Thanks, PF
Old Nov 11, 2005 | 03:03 AM
Kuppler's Avatar
I just did this acouple weeks ago, I ran my amp cables to the trunk, I just took off the kick plate, the seatbelt cover just pops off, then I ran it under the seat and pulled it out in the trunk from behind the seat. I wasn't able to find a way to run the power cable through the firewall so i ran it under the car. Under car near the back there is a little pop out i guess what would be a plug I just popped off and drilled a hole under the back seat right over the plug and was able to get the power out from there... don't know if this helped but thats my experience with it.
revbourbon
Jun 15, 2011 06:24 PM
yohan
Dec 24, 2006 09:04 PM
turbo
Sep 9, 2005 03:54 PM
GeilKyle2
Jul 19, 2005 03:40 AM
wrax
Apr 18, 2005 08:19 AM
