HELP: Vag-Com fault codes Please help
Old Nov 28, 2007 | 08:44 PM
1Move's Avatar
Default HELP: Vag-Com fault codes Please help
Hey guys just ran a scan with a vag-com and these are the error codes i got does anyone know how to fix these???? are they done manually or through vag-com???
2004 1.8t tip
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 16236
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0004
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
5 Faults Found:
01403 - Glass-Break Sensors; Rear
36-00 - Open Circuit
01559 - Drivers Door
61-10 - Won't De-Safe - Intermittent
01560 - Passenger Door
01561 - Left Rear Door
01562 - Right Rear Door
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -[/align]
Old Nov 28, 2007 | 08:50 PM
hiwords's Avatar
Default RE: HELP: Vag-Com fault codes Please help
clear them and see if they come back
Old Nov 28, 2007 | 10:41 PM
1Move's Avatar
already did a few times keeps coming back
Old Nov 28, 2007 | 10:49 PM
auditech79's Avatar
Never seen those fault codes before, there is probably something wrong with the module.
Old Nov 28, 2007 | 10:59 PM
hiwords's Avatar
i must agree. see here http://www.bentleypublishers.com/tec....dtc.table.htm
if auditech79 can't find it, ur in deep doodoo lol. i guess if u have ur radio code, u could try unplugging the battery for like an hour or something and see if something good happens
Old Dec 1, 2007 | 05:37 PM
dankhound's Avatar
Are you experiencing problems with the system or do you just want to be fault free? Sometimes these cars throw odd codes for no reason. The open circuit fault is for the motion sensor for interior monitoring. You have either a module or sensor that is bad or a wire that isnt connected. The unsafe fault codes trip sometimes if a latch is bad other times they just show up. They dont really mean much of anything becauseUS cars dont even use that safety system. Its a second motor that physically locks the latch in place.
m.c.
May 2, 2012 01:40 PM
PandaXpress
Jul 25, 2009 10:47 AM
paulrob2808
Aug 28, 2007 04:18 PM
mitao2000
Aug 30, 2006 11:53 AM
BaconBait
Aug 8, 2005 08:21 PM
