Vag Fault Codes
Old Aug 8, 2005 | 07:16 PM
BaconBait's Avatar
Default Vag Fault Codes
Anyone know how to fix these? I did a google search, but came up with no useful information.
00 A4 1.8t quattro manual
Address 01: Engine
Controller: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07201
Shop #: WSC 85555
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Idle seems normal. All other codes I knew about (damn fuel sending unit).
Old Aug 8, 2005 | 07:49 PM
InsaneHatter's Avatar
Default RE: Vag Fault Codes
for the P0300 Codes:
What does that mean?Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 OBD code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
SymptomsSymptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
CausesA code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible SolutionsIf there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
For the other code:
Is your battery have the right voltage?
Did you disconnect the ecu?
Clear the P1602 Codes if you did disconnect the ECU
What did you do before this happened?
Old Aug 8, 2005 | 08:11 PM
Jestnomen's Avatar
6th Gear
yeah the last fault code can come if the battery dies, or the ECU has been disconnected.
Old Aug 8, 2005 | 08:21 PM
BaconBait's Avatar
Holy carp that's a lot of causes. Could it still be the coil pack if there's no fault on the #1 cylinder? I also don't have any of those symptoms. I'll try clearing the codes.
I don't think I did anything.
BaconBait's Avatar
Aha! The battery died while I was deployed.
m.c.
May 2, 2012 01:40 PM
PandaXpress
Jul 25, 2009 10:47 AM
1Move
Dec 1, 2007 05:37 PM
paulrob2808
Aug 28, 2007 04:18 PM
mitao2000
Aug 30, 2006 11:53 AM
