Here's the gameplan... UPGRADES
Old Feb 3, 2007 | 09:20 PM
AML 225's Avatar
Default Here's the gameplan... UPGRADES
Well using the superhelpful links sticky at the top I assembled a list of semi-longterm goals for upgrades with my car. I've got the timing belt coming up and my cars going in for a service in a few weeks. I figure after the service I'll start upgrading making sure not to forget about the timing belt job.
Here's the list I assembled I'm wondering if anyone could just critique maybe there are better options or lower prices from other places. Any advice would be much appreciated.
One or two of the items have big -OR- 's between them that's because I'm not sure what the best option is. If you know, let me know! ;-) Thanks guys!
H&R Coilovers
Pure MS
http://www.purems.com/products/products.php/CA=1471
Borla cab-back exhaust
Pure MS
http://www.purems.com/products/product.php/II=1007
RS4 Engine Mounts
Pure MS (or shop around)
http://www.purems.com/products/product.php/II=1037
-OR-
APR Snub Mount
http://www.purems.com/products/product.php/II=1217
Bailey MS DV
AWE Tuning
http://www.awe-tuning.com/pages/shar...IL=BaileyValve
GIAC 1.8t Chip
Local Shop most likely
New (larger) brake rotors (probably cross drilled) and some mintex pads.
Old Feb 3, 2007 | 10:38 PM
BaconBait's Avatar
Default RE: Here's the gameplan... UPGRADES
Nice list there.
You can get the RS4 motor mounts and the Snub mount. The motor mounts are between the motor and the wheels. The snub mount goes on the front of the motor.
For your brakes, the only larger rotor you can get while retaining the stock caliper the the A8 upgrade. It's basically the A8 rotors, TT caliper carrier, and stock caliper. I recommend getting braided lines also if you do go that route. It's a nice cheap upgrade. You may also want to consider the Boxster upgrade kit from Pure MS.
Old Feb 4, 2007 | 12:25 AM
Dj Spiel's Avatar
i had a bad expierence with purems they sent me wrong parts 2 times.
just fyi.
Old Feb 4, 2007 | 01:05 AM
AML 225's Avatar
Can I get more info on the boxster upgrade kit? Sounds intriguing.
Old Feb 4, 2007 | 01:10 AM
Lazer Viking's Avatar
go to their web site
Old Feb 4, 2007 | 01:27 AM
Amze's Avatar
Sounds like a good future, follow through
Old Feb 4, 2007 | 02:43 AM
BaconBait's Avatar
ORIGINAL: Dj Spiel
just fyi.
Did they fix it?
LVracerGT
Nov 3, 2010 09:52 PM
whytap109
Jun 24, 2007 02:58 PM
lagartijoquattro
Jun 14, 2007 10:30 PM
GL8386
May 10, 2006 01:52 AM
itsquattro
Aug 4, 2005 04:02 AM
