HID Resister Fix Question
Hey Guys, I'm attempting to do the resister trick to fix the "dippedleft/right headlight" errors. I'm a bit confused where the resister is actually suppose to go. My setup is using vision bulbs conversion kit. I had issues with the plug and play option (random dash lights flashing), so i switched to the harrness supplyed with the kit. I thought the resister was suppose to go in between the positive and negative wires on the 2 prongconnector that use to plugin into the stock H7 holligen bulbs. I have tried this for the pas couple hours with no luck. If any one could point me in the right direction it would be much apprechated.
Thanks,
~Jamie
Thanks,
~Jamie
i had this issue as well, but using a 6ohm resistor seems to have worked (been driving around for a day with it).
Have not ordered from these guys, but this will give you an idea of what the resistor looks like:
http://autolumination.com/equalizers.htm
you need the 6 ohm deluxe aluminum load equalizer (1 for each side).
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
