HIDs installed!
Old Jul 15, 2007 | 12:15 PM
whitejeepXJ's Avatar
Default HIDs installed!
Hi guys,
Installed a set of 8000k HIDS on my 01 B5... looks great but I got that darn burnt headlight signal lamp going off and it annoys me..
I did some searching and it says to add some resisitors to trick the car into thinking the lights are there.
Anyone else got any ideas that are quicker and dont require me to go out to the store... its sunday and im lazy!
Note: I did the relay install, do most people just do the plug and play install instead??
Thanks,
Michael
Old Jul 15, 2007 | 12:29 PM
klum00's Avatar
Default RE: HIDs installed!
I did plug and play for mine, and no problem with a burnt light warning. I think the only way to really get that to go away is the resistor, so get your lazy *** off the couch!
Old Jul 15, 2007 | 11:25 PM
S_R_N83's Avatar
Go to radioshack
Buy the resistors (very cheap)
Put them in (takes seriously 2 mins)
I did plug and play install with the resistors--no problem.
Old Jul 16, 2007 | 01:39 AM
cbdr18's Avatar
wat is a resistor? or wat does it do?
Old Jul 16, 2007 | 03:50 AM
CLX's Avatar
CLX
Zombie Defense Force
Do you mean 'what?'
A resistor is what it sounds like it is. Simply put, it restricts the flow of electricity. The halogen lamps have far more current draw than the xenons, so the car thinks that they are burnt out.
Old Jul 16, 2007 | 04:32 AM
thekyman's Avatar
ORIGINAL: cyberlogicx
Do you mean 'what?'
wouldnt this be the opposite of what you want to do though? stock halogens run at like 55w and HIDs run somewhere around 35w, so the computer is reading a low current draw. so wouldnt a resistor make it even lower?... i had the same problem and put in resistors and it made the HIDs very dim and flickered..
Old Jul 16, 2007 | 04:41 AM
CLX's Avatar
CLX
I think the computer just gives the message because it's reading an incorrect current draw. I could be wrong though, I'm not good with electricity
Old Jul 16, 2007 | 05:11 AM
Belligerenceā„¢'s Avatar
weird, I did the plug & play install on mine, with no resistors and I don't get a burnt out light warning thing. am I special or something?[&:]
Old Jul 16, 2007 | 08:18 AM
ironman's Avatar
take some pics of the new HIDS
Old Jul 16, 2007 | 09:07 AM
ORIGINAL: Belligerenceā„¢
I didn't do the plug and play install... i installed with the relay harness so i have one of the stock headlight connectors not plugged to anything....
