Higher milage A4's?
Old Oct 15, 2007 | 08:34 PM
awoodman's Avatar
Default Higher milage A4's?
Im in the market for an audi a4. I have about $6,000 to spend on the car, itself. I've found a couple with aroule 130k miles on them. Is there anything I should pay close attention to when looking at them or anything I should worry about with an audi with this mileage? thanks
Old Oct 15, 2007 | 08:51 PM
sineo's Avatar
Default RE: Higher milage A4's?
There are probably better key words, but if you search for, "problem areas," you'll find several good threads about people looking into A4s and the recommendations forum members give.
Old Oct 15, 2007 | 08:59 PM
hiwords's Avatar
if ur buying an A4 with that many miles, i suggest u get the 2.8 because it's more reliable. the thing to worry about is the timing belt. that's the major one. another thing is the history of the vehicle.
Old Oct 16, 2007 | 03:45 AM
david9999's Avatar
My 1.8 has 190K miles on it.
Usual suspects are control arms, wheel bearings, engine sludge, and timing belt.
Check that the belt has been done previously.
Have a good VW/Audi mechanic check it out before you buy and also have him check the oil pressure as the pickup screen can get clogged with sludge. At least you know what you are getting into.
As with any high mile used car, plan on spending 1000 dollars in the first year to take care of the things that the previous owner has neglected.
Old Oct 16, 2007 | 11:54 AM
mtyrrell's Avatar
Member
definatley go w/ a 2.8 in my opinion with higher mileage. the 2.8s have greater longevity than the 1.8swith the wear and tear that comes wiht having a turbo
Old Oct 16, 2007 | 11:56 AM
mtyrrell's Avatar
Member
my 2.8 is closing in on 130k, but properly maintained it runs like a charm
Old Oct 16, 2007 | 01:33 PM
80sGuy's Avatar
ORIGINAL: mtyrrell
It really depends how the car was taken care of by the previous owner. I've seen some 'dogs' on 2.8s compared to a well maintained 1.8 Turbo.
seattle206
Jul 18, 2011 10:01 AM
deub
Dec 16, 2008 12:41 PM
EliteTuning1
May 3, 2007 02:09 AM
David_K
Aug 12, 2004 01:41 PM
apexiA4
Apr 17, 2004 04:35 AM
