How to access Central Flap Motor (A/C issue G112 Error)
Old Jun 27, 2007 | 09:03 AM
aRIf's Avatar
Default How to access Central Flap Motor (A/C issue G112 Error)
I had a problem with my a/c couple weeks ago. I tought it was leaking but it was not the problem. When I turn the a/c on, a/c pipe gets ice cold but do not blow any cold air but cool air sometimes.
I accessed to diagnostic tool thru temp screen and got 111 error which means;
11.1 (G112) Central Flap Motor Potentiometer, static open, *11.1 (see below)
11.2 Central Flap Motor Potentiometer, static short, see 11.1
So I'm thinking either motor is bad, or flap is stuck or something.
Is anybody change the flap motor or any pics or instructions how to access it ?
Thanks
FYI: Diagnostic information link
http://www.audiworld.com/tech/int6.shtml
Old Jun 27, 2007 | 12:37 PM
acetrebo's Avatar
Default RE: How to access Central Flap Motor (A/C issue G112 Error)
See if this helps...
Old Jun 27, 2007 | 01:33 PM
aRIf's Avatar
Thanks acetrebo. Sure it will help. onepoint8tee also sent me some pics so this friday will be a busy day
I wish i could find some diy stuff but none so far
Old Jun 27, 2007 | 09:47 PM
aRIf's Avatar
Wow. I took everything apart. I feel a backpain so bad but I think I found the problem. as I tought before, I was wrong. I had a leak.
as far as i understand problem is the seals; they become like a gum. i need to buy new seals and try it again see if it helps. all the flaps and stuff are working fine as far as i checked.
yellow_submarine
Jun 4, 2011 01:22 PM
ne2q 73
Jan 17, 2008 12:29 PM
three_spirits
Sep 10, 2006 02:31 PM
ScottA8L
Feb 15, 2006 03:26 AM
ScottA8L
Feb 14, 2006 04:24 PM
