How could you pin point ......
Old Jun 22, 2005 | 07:28 PM
dudley doright's Avatar
Default How could you pin point ......
........the hose that has the leak?
Old Jun 22, 2005 | 07:30 PM
a4autocrossr's Avatar
Default RE: How could you pin point ......
lets be a littel less vague/waht are your symptoms??
--E
Old Jun 22, 2005 | 07:33 PM
robby's Avatar
Air leak or Water leak?
water hose if leaking will let either steam or water out, air hose might have visable crack/ split - to confirm dab some water onto the split and see if it bubbles with the air
Old Jun 22, 2005 | 07:52 PM
InsaneHatter's Avatar
Get some soapy water in a spray bottle and spray the hoses in question. If you see bubbles.. leak.... This is for air leak.
You could also use some type of smoke system to run through it.
Easiest is soap.
For water leak.... uhhhh dripping liquid?
Old Jun 22, 2005 | 10:21 PM
99a4audi's Avatar
try soapy water, and put that over the hose u think that has a leak and if there is a leak it should bubble
Old Jun 23, 2005 | 02:53 PM
I meant to say is vacuum leak. Anyone use the propane gas test?
fredct
Jun 16, 2015 10:57 AM
jdahlen24
Nov 8, 2011 08:50 PM
smarsenal
Mar 26, 2008 11:27 PM
Darth Vader
Nov 6, 2005 06:14 PM
wrax
Apr 25, 2005 04:43 PM
