How could you tell if the Turbo has failed?
Old Jun 30, 2004 | 11:41 AM
dudley doright's Avatar
Default How could you tell if the Turbo has failed?
I never heard the whistling sound of the turbo even when I first test drove this car so I don't know if the turbo actually works or not. What are the tell tale signs that the turbo has failed? Do I get a sluggish acceleration? Does the car hesitate when accelerating? I am not sure what it is and I will appreciate if someone could tell me.
Old Jun 30, 2004 | 01:39 PM
CRAZYHAWK's Avatar
Default RE: How could you tell if the Turbo has failed?
When you accelerate , it will be gradual. If will produce about 2/3 of its potential power. If you use low octane fuel performance will be slightly worse due to retarded spark.
Old Jun 30, 2004 | 01:46 PM
brrman's Avatar
If your turbo has died, you will be in limp mode. You will have 90 hp. And your car will be a slug and you will KNOW that something is wrong believe me. It will not be just a small difference.
You cannot normally hear the turbo spool on a stock A4. Once you are chipped, however, you will hear it quite often.
Old Jun 30, 2004 | 06:54 PM
ImolaS4's Avatar
ORIGINAL: brrman
Well said.
Old Jun 30, 2004 | 11:59 PM
fresh1's Avatar
Speaking of hearing your turbo spool up.... My car has been chipped and yeh i can hear the turbo spool up when i put my foot down,
BUT when i first start my car and im driving for a bit before my engine warms up, if i put my foot down i can hear the turbo spool but its not a really smooth sounding whistle. It sounds more like a fan or something (sounds almost like a fan belt rubbing kind of noise) its not loud but it just sounds a bit odd to me.
This only happens when the engine is cold though.... once its warm its ok....
I havent had any problems at all with the turbo and i have had the car for 8 months now. Any ideas what that noise would be from?
Any help would be great!
Old Jul 1, 2004 | 04:15 AM
ImolaS4's Avatar
This may be because the turbo is working hard before the oil has warmed to operating temp.
smogthemog
Jan 21, 2011 03:19 PM
chocalotstarfish
Dec 15, 2010 11:11 PM
BLK_A4
Dec 8, 2007 02:37 PM
Boober
Jul 20, 2006 04:32 AM
Dj Spiel
Apr 16, 2006 06:52 AM
