How do the 2.8s hold up with E85??
Your car is not designed to run on E85. E85 is an 85 percent blend of ethanol. Your car requires premium unleaded gasoline. Which at most contains 10 percent alcohol, thou usually less.
Well guys, The E85 has a higher octane equivelent rating than premium unleaded. It burns cooler. The thing I'd worry about is the fuel lines and fuel pump. Ethanol is a better fuel than petroleum fuel.
you can actualy start to loose power going with higher octain fuel than the unmoded car was originaly intended. the fuel will still be burning on it whay out the exhaust with a low compression.
