How much PSI can this DV hold?
Old Oct 5, 2007 | 11:21 AM
Grafixs's Avatar
Default How much PSI can this DV hold?
http://www.4induktion.com/catalog/pr...roducts_id=196
Thinking about ordering one to go along with the GIAC chip ill be getting soon. I know you need a new DV and don't feel like spending 250 on a 007.
Thanks for your replys
Old Oct 5, 2007 | 12:33 PM
Papachristou's Avatar
Default RE: How much PSI can this DV hold?
autobahn imports had a buy on the 007p with the spring kit for $125 shipped
where are u getting $250?
i thought at most they were $150 or so.. i have an APR R1 for $160
Old Oct 5, 2007 | 01:44 PM
cincyTT's Avatar
I'm make believe
If you have a 2.0T, you need to either spend more for a forge dv/bov, deal with a weak stock bypass, or go to atp and get an adapter to bolt on a regular style dv/bov (greddy, hks, 1.8t style dv's)
Old Oct 5, 2007 | 01:47 PM
socal_A4's Avatar
ill sell you my forge 007 with the spring and shim kit for a good price
Old Oct 5, 2007 | 02:33 PM
chaos92287's Avatar
http://www.audizine.com/forum/showthread.php?t=135700
forge 007 for 75 bucks
Old Oct 5, 2007 | 02:39 PM
auditech79's Avatar
You should also change the PCV valve with an updated one, thats another weak point on the 2.0T engine when you start boosting higher than normal pressures. I read that somewhere on audiworld.
Old Oct 15, 2007 | 11:23 AM
patty AT forge's Avatar
You have two posts saying you don't want to spend $250 on a 007 for your car. The 007 neither costs $250 nor will it work for your car.
The $250 valve for your car is the FMDVFSITV, commonly called the FSITV...
PandaXpress
May 18, 2008 06:54 PM
cowfat
Apr 20, 2006 01:19 PM
viziers
Apr 7, 2006 01:39 PM
hitwriter
Apr 4, 2006 07:49 PM
rowingdude
Oct 23, 2005 12:21 AM
