How do the 2.8s hold up with E85??
Old Oct 20, 2005 | 07:39 PM
rowingdude's Avatar
Default How do the 2.8s hold up with E85??
I am very curious..
Old Oct 21, 2005 | 05:02 PM
dankhound's Avatar
Default RE: How do the 2.8s hold up with E85??
Your car is not designed to run on E85. E85 is an 85 percent blend of ethanol. Your car requires premium unleaded gasoline. Which at most contains 10 percent alcohol, thou usually less.
Old Oct 21, 2005 | 06:36 PM
flyboy's Avatar
I seriosly doubt it would even run
Old Oct 21, 2005 | 09:08 PM
brent07's Avatar
simply dont do it ... its that simple ... i ran 87octane once and that was a bad idea .. just imagine what e85 would be like if it even worked ...
Old Oct 21, 2005 | 11:01 PM
gregp1962's Avatar
Well guys, The E85 has a higher octane equivelent rating than premium unleaded. It burns cooler. The thing I'd worry about is the fuel lines and fuel pump. Ethanol is a better fuel than petroleum fuel.
Old Oct 22, 2005 | 03:49 AM
flyboy's Avatar
if it has those qualitys, I would expect that like other higher octain fuels that it would burn more slowly, Needing advanced timing or a higher compression ratio.
Old Oct 22, 2005 | 03:11 PM
gregp1962's Avatar
Flyboy, you could be right. But, the 1.8t requires premium anyway. I'm not sure about the 2.8.
What do the makers of E85 say about running it in an unaltered car?
Old Oct 22, 2005 | 03:40 PM
flyboy's Avatar
you can actualy start to loose power going with higher octain fuel than the unmoded car was originaly intended. the fuel will still be burning on it whay out the exhaust with a low compression.
Old Oct 23, 2005 | 12:21 AM
jlaudio184's Avatar
how expensive is E85, ive never seen it
PandaXpress
May 18, 2008 06:54 PM
Grafixs
Oct 15, 2007 11:23 AM
cowfat
Apr 20, 2006 01:19 PM
viziers
Apr 7, 2006 01:39 PM
hitwriter
Apr 4, 2006 07:49 PM
