How do you Check the Trans Fluid???
Old Jan 2, 2006 | 03:11 PM
uscourt3000's Avatar
Default How do you Check the Trans Fluid???
Er... where do you check the transmission fluid level?? (New car... 1.8T )
I kinda suspect the same fluid is used for the engine and the transmission... but mebbe not??
Old Jan 2, 2006 | 03:15 PM
dan908's Avatar
Default RE: How do you Check the Trans Fluid???
First dibs
It is a sealed transmission. Technically you can check it through the fill hole, but there is no dipstick.
Old Jan 2, 2006 | 03:20 PM
drkenan's Avatar
Yep you have to stick your little finger in there and wiggle around and see if you feel any fluid. Thanks for reminding me that I need to do that to my leaking rear differential.
Old Jan 2, 2006 | 04:50 PM
Cool! So there should be no need for top-ups! Er, where is this little fill hole, anyhow?
This is my first Audi. I normally always buy the manufacturer's workshop manual, which should give me more information than I should ever need, but the manual doesn't look as if it's available. Certainly, the salesman poo-pooed the idea (of getting the manual), since the first 50,000 miles of maintenance are fully covered by Audi.
Old Jan 2, 2006 | 07:21 PM
John_E's Avatar
Particularly for congested city or suburban driving, changing the ATF at least every 60k mi = 100k km is sound preventive maintenance, even though many dealerships won't touch the transmission.
Old Jan 3, 2006 | 01:22 AM
david9999's Avatar
The fill hole is on the bottom of the transmission. The ATF fluid has to be checked with the car level and the fluid at a particular temperature. It is hard to get it right without a VAGCOM and a lift to keep the car level.
yellow_submarine
Feb 3, 2011 04:25 AM
vtraudt
Nov 10, 2010 02:38 PM
vtraudt
Nov 9, 2010 10:38 AM
jseel
Oct 19, 2010 11:06 PM
Rog226
Oct 10, 2006 11:25 PM
