A5 B5 2.8 auto: trans fluid check, fill
Old Nov 9, 2010 | 10:38 AM
vtraudt's Avatar
Default A5 B5 2.8 auto: trans fluid check, fill
Can someone quickly send me instructions how to
- check transmission fluid level?
- add trans fluid?
I installed used trans, not sure what fluid is in. I don't want to drain completely (read on forums that I also loose 'good' parts when draining), may drop the pan and change filter (after first test drives) as a compromise.
I plan to use a readily available trans fluid (Mobile ATV synthetic), not the Audi special (seems to be the consent that Mobile ATV (Amsoil mentioned also often, but less readily available) works fine.
NoAudiGuy
B7 Models
Dec 16, 2016 05:13 AM
vtraudt
Nov 10, 2010 02:38 PM
fromerich
May 9, 2010 08:48 AM
RIA6
Nov 3, 2006 01:58 AM
uscourt3000
Jan 3, 2006 01:22 AM
