how do you do a brake flush???
Basically all your doing is a brake fluid change. This is most easily done with one of the pressure bleaders on the market, but can be done using the gravity bleeding method. Basically you just crack the bleaders one at a time untill clean fluid comes out. While doing that make sure the master cylinder doesnt run dry.
n_gunjan
Mar 8, 2010 05:05 PM
