flush brake fluid
By bad fluid, I assume you mean wrong DOT spec. Not sure on the specifics of if you fucked anything up, but just do it like a brake bleed and just keep running fluid through the system. Make sure you don't run the master cyl. dry too. Or you can pick up a power bleeder, hook it up to your air compressor and suck the fluid out. Brake bleeder is a little extreme for one time use, but its great when you bleed/flush brakes all day like I used to.
ECS Tuning
Oct 30, 2014 03:54 PM
frizzlefry
Jun 3, 2010 08:35 PM
n_gunjan
Mar 8, 2010 05:05 PM
