How do you remove headlamp
Old Oct 3, 2007 | 10:16 AM
mique's Avatar
Default How do you remove headlamp
2000 A4 1.8
I have a one piece headlamp assembly that I am trying to remove. I have removed the tork screws and disconnected the wires. I can pull the headlamp forward on the grill side, but the outside where the indicator lamp is will not move. Any advise is appreciated.
Old Oct 3, 2007 | 10:17 AM
ironman's Avatar
Default RE: How do you remove headlamp
search the forums and why did u post 3 thread for this there are 4 screws look!!!
Old Oct 3, 2007 | 10:27 AM
micah's Avatar
actually, 3 screws...two torx screws on the top, and one if you look straight down the hole at the corner of the front quarter panel...there is another torx screw there that you must remove...usually requires an extension to get to it and a magnet
Old Oct 3, 2007 | 10:29 AM
mique's Avatar
I did search the forum first but came up empty!
I do not know why there are 3 posts. I did have a problem with my first post not being accepted. then when I posted again it magically appeared.
So, I still need help. You say four screws, I removed the two from the top but am unable to see where there would be any others!
Old Oct 3, 2007 | 10:33 AM
mique's Avatar
Great, thanks, I see the screw. Yes an extension with magnet is needed. Thanks for your help.
tommymasar
May 5, 2013 04:14 PM
mique
Oct 3, 2007 10:13 AM
mique
Oct 3, 2007 10:12 AM
clash8488
Jan 31, 2007 08:09 PM
soccrstar
Mar 14, 2006 11:00 PM
