How much PSI can this DV hold?
http://www.4induktion.com/catalog/pr...roducts_id=196
Thinking about ordering one to go along with the GIAC chip ill be getting soon. I know you need a new DV and don't feel like spending 250 on a 007.
Thanks for your replys
If you have a 2.0T, you need to either spend more for a forge dv/bov, deal with a weak stock bypass, or go to atp and get an adapter to bolt on a regular style dv/bov (greddy, hks, 1.8t style dv's)
You should also change the PCV valve with an updated one, thats another weak point on the 2.0T engine when you start boosting higher than normal pressures. I read that somewhere on audiworld.
You have two posts saying you don't want to spend $250 on a 007 for your car. The 007 neither costs $250 nor will it work for your car.
The $250 valve for your car is the FMDVFSITV, commonly called the FSITV...
