Hybrid ko3
ORIGINAL: oneg
DO YOU NOT ****** LISTEN TO ME???
or does cincy just have to say it for you to beleive it?!?
you just need the f'ing turbo, a one with TONS of shaft play is perfect since you are replacing it anyways and you can get it cheaper
sorry
so i should get the ko3s and rebuild it with this kit?, or just buy one in good shape and bolt it right on? and if it doesnt specify if its a ko3s, what other characteristics are ther to determine its a ko3s and not ko3? whats the diff. in the comp wheel or housing size?
ok my understanding of the k03s is this: it's the same as the k03 on the hot side, and the same as the k04 on the cold side. so that being said, why do you need a k03s if you're going to replace the cold side anyway? just get a used k03 with a sh*t ton of shaft play like cincy is telling you to.
