Hybrid ko3
Old Oct 18, 2007 | 09:57 PM
  #21
kemp_travis's Avatar
Default RE: Hybrid ko3
so couldnt i just find a ko4 comp. housing/wheel and put that in my existing ko3?
Old Oct 18, 2007 | 09:58 PM
  #22
with no shaftplay?
what advantages would i get from the swap
Old Oct 18, 2007 | 10:01 PM
  #23
oneg's Avatar
ORIGINAL: kemp_travis
well how much do these k03s cost
DO YOU NOT ****** LISTEN TO ME???
or does cincy just have to say it for you to beleive it?!?
Old Oct 18, 2007 | 10:02 PM
  #24
i typed it out before i read your post jacka$$
  #25
cincyTT's Avatar
I'm make believe
ORIGINAL: oneg
doesnt matter who says anything. he doenst grasp concepts and makes you want to put your head through a wall.
you just need the f'ing turbo, a one with TONS of shaft play is perfect since you are replacing it anyways and you can get it cheaper
Old Oct 18, 2007 | 10:03 PM
  #26
cincyTT's Avatar
I'm make believe
^ why no one wants to help you
Old Oct 18, 2007 | 10:07 PM
  #27
oneg's Avatar
agreed, and you neglected what i said until cincy said it about 3 times already. just do it, and see how it works.
Old Oct 18, 2007 | 10:08 PM
  #28
Belligerenceā„¢'s Avatar
yet another thread started by kemp that's turning into a sh*tshow I see.[:-]
Old Oct 18, 2007 | 10:11 PM
  #29
sorry
so i should get the ko3s and rebuild it with this kit?, or just buy one in good shape and bolt it right on? and if it doesnt specify if its a ko3s, what other characteristics are ther to determine its a ko3s and not ko3? whats the diff. in the comp wheel or housing size?
Old Oct 18, 2007 | 10:15 PM
  #30
ok my understanding of the k03s is this: it's the same as the k03 on the hot side, and the same as the k04 on the cold side. so that being said, why do you need a k03s if you're going to replace the cold side anyway? just get a used k03 with a sh*t ton of shaft play like cincy is telling you to.
