i got my new clutch and WFT
so i got my car back today i put a stage 3 south bend clutch. the clutch works amazing but heres my problem. my stick feels a lot looser and move side to side about2 incheswhen i put it in gear. it wasnt like that when i brought it in and the guy who did the clutch says "i think thats right." So what do i need to replace?
good choice on the south bend clutch man, i got the same one installed with a lightweight flywheel. Sounds like they might have not put the pin in your shifter back in. Meaning, there is a pin that holds your shifter to the trans together and it might be falling out. You can check by taking the shift boot apart and looking inside.
pull the shift boot off and look at the linkage. All the bars you see should not have any play in them. The nuts on the linkage should be really tight because from the factory they come with lock tight.
ivanruiz817
Sep 16, 2011 02:38 AM
loves4
Feb 12, 2008 08:45 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
