I have an 01 1.8t that wont excelerate.
Old Jun 23, 2006 | 05:09 PM
blkapra4's Avatar
Default I have an 01 1.8t that wont excelerate.
have nothing to do with this post. But now that i have your attention. I have an 01 1.8t that wont excelerate. At partial throttle the car takes off ,but as soon as i give it half or full throttle the car falls on its face. (wont excelerate at all) I'm thinking that this is a faulty diverter valve am i correct?
EDIT: changed title of this thread... brrman
Old Jun 23, 2006 | 05:11 PM
JohnnyBravoA4's Avatar
Default RE: GIANT BREASTS!!!
could be alot of things do you have a boost gauge
Old Jun 23, 2006 | 05:26 PM
apercele79's Avatar
ok ok i'm here, i ran as fast as i could...
where the ******* at ???
Old Jun 23, 2006 | 05:28 PM
blkapra4's Avatar
no boost gauge... what else could it be?
Old Jun 23, 2006 | 05:34 PM
wood_e's Avatar
Check for boost leaks... maybe you have a hose that isn't tight
Old Jun 23, 2006 | 05:36 PM
blkapra4's Avatar
i already brought the car to the place i purchased it from they checked all the hoses and sai they couldn't find a leak
Old Jun 23, 2006 | 05:39 PM
is the car all stock, any mods and if so what are they.. need a little more info.. no check engine light..
Old Jun 23, 2006 | 05:42 PM
blkapra4's Avatar
no cels car is completely stock with the exception of a kn panel filter.... fyi turbo is very loud
Old Jun 23, 2006 | 05:43 PM
luvin_the_rings's Avatar
i had the same problem, it was a coil pack
is the cutting out sudden and jerky, or sort of smoothe and it feels like there is just no power.
coil pack = sudden cut out and jerkyness
somthing else = smooth decline of power
Old Jun 23, 2006 | 05:46 PM
turbo is very lound.. interesting.. loud compared to what? have you been in another audi to compare it to.. I would get a boost gauge to see what your boost is at even if you just buy a cheep one and dont fully install it atleast you can eliminate a boost problem, could be getting a limp mode which restricts the boost.. also try disconecting the MAf to and drive it around see if that changes anything..
how many miles on the car?
