important timing belt change, why?
Old Jan 23, 2005 | 05:11 PM
OUT_T_1.8's Avatar
Default important timing belt change, why?
why is it so important to replace the timing belt before it breaks on these audi's? i broke my timing belt on my mr2 doing 70+mph, everything just shut off, towed it to my mechanic, put new belt on, was on the road again. no motor probs or anything. i belive if it aint broke, dont fix it.
Old Jan 23, 2005 | 05:15 PM
Jestnomen's Avatar
6th Gear
Default RE: important timing belt change, why?
Audi's have interference engines. If the timing belt breaks, the pisons will hit the valves causing a LOT of damage. $$$$
Old Jan 23, 2005 | 05:24 PM
OUT_T_1.8's Avatar
damn thats sucky. what type of motor is in the mr2? non-interferience??
Old Jan 23, 2005 | 05:37 PM
Jestnomen's Avatar
6th Gear
Both the MK1 and MK2 are non-interference engines.
Old Jan 23, 2005 | 05:57 PM
OUT_T_1.8's Avatar
sounds silly that they wouldnt just make all motors non-interferince. or maybe its part of an audi scandal to make us all pay dearly at stealerships
Old Jan 23, 2005 | 10:05 PM
david9999's Avatar
Unfortunately, most engines are interference. One major exception are the toyota engines. Somewhere I have a PDF of engine type.
Old Jan 23, 2005 | 11:46 PM
PandaXpress's Avatar
if u dont change your belt this is whats gonna happen, your valves stay open and your pistens start poundin them and damagin everything
Old Jan 24, 2005 | 02:40 AM
TripN's Avatar
At what Mileage do you guys recommend changing the timing belt on a car with normal daily driving 'wear and tear'.
Old Jan 24, 2005 | 02:41 AM
audiboy1618's Avatar
60k to 80k with NORMAL driving.
Old Jan 24, 2005 | 09:01 AM
david9999's Avatar
Dpeends, most of the failures are due to failure of the timing belt tensioner. The tensioner has been updated to a more reliable design. My car recommends 105K miles to do it (2000 ATW engine). That said, I replaced everything at 80K miles, including the front seals.
Better safe than sorry.
TheFrostyArab
Oct 1, 2012 05:37 PM
MillerDecaXC
Jan 25, 2012 08:09 PM
umitbat
Oct 19, 2009 12:05 PM
SouthernAudi
Oct 14, 2007 03:55 AM
juice88
Aug 5, 2005 11:42 AM
