Installing BOV
Old Jan 8, 2005 | 04:50 PM
  #21
audiboy1618's Avatar
Default RE: Installing BOV
lol oh, run that bov with the stock motor for awhile and come back and tell us how its going. Sounds like its goin great already so we should have some good feedback from it.
Old Jan 8, 2005 | 04:54 PM
  #22
morrisonjd84's Avatar
it sounds like its going great because im not experince with bov" just dont have it tuned right yet im not having any problems
Old Jan 8, 2005 | 05:04 PM
  #23
Get some boost going so you have something to blow off. Your only making prolly 148hp with that thing, there is prolly not enough boost for it to make the noise you want it too. keep in mind, i know nothing and i "regurgitate(sp?)" everything i read. I would talk to greenday more for your tuning needs as it sounds like he knows the most about it. Happy tuning.
Old Jan 8, 2005 | 05:10 PM
  #24
flyboy's Avatar
I don't want to join sides, but[sm=roll.gif][sm=thanx.gif]
Old Jan 8, 2005 | 05:12 PM
  #25
thats what i thought too but if im pushing around 8psi that should be plenty
Old Jan 8, 2005 | 05:13 PM
  #26
flyboy's Avatar
I really don't know much about the audi turbo cars but eight sounds kinda low.
Old Jan 8, 2005 | 05:20 PM
  #27
Transverse's Avatar
That should be what you are pushing...unless you're losing some boost here or there. Have you noticed any performance differences? If this is an "upgrade" from the 710A DV then you should definitely notice an increase in throttle percision. Boost for stock 1.8T is roughly 8psi on a B5, but it CAN spike to 10psi. The 710A is rated for ~8psi so you could even find that you're getting a smidge more power in some instances.
If it feels the same or worse, you're probably loosing boost somewhere. I believe AW has a tutorial on finding boost leaks.
-T
Old Jan 8, 2005 | 10:28 PM
  #28
greenday's Avatar
im telling ya, the spring or vaccume insert is too stiff for the amount of bost your running, many na turbo kitted cars only run 6-10 psi, and they will blow off just fine, its all in the adjustments/spring rates/vaccume rubber stiffness. but ya, get more boost and it will make a better sound and i think you might like the power too.
Old Jan 9, 2005 | 12:09 AM
  #29
trailboss's Avatar
bov's dont make more power, lol, they bring the civic rice factor up though.
Old Jan 9, 2005 | 08:58 PM
  #30
David_K's Avatar
you will experience problems with a BOV down the line. the big one being a broken O2 sensor or a plugged cat. things that can be fixed very cheaply
