Installing Downpipe. Tips?
Old Jul 13, 2007 | 11:16 AM
ballswell's Avatar
Default Installing Downpipe. Tips?
Finally getting around to installing my test pipe tomorrow. Does anyone who has been through the proceedure provide some tips?
Old Jul 13, 2007 | 11:30 AM
Black_97 A4's Avatar
Default RE: Installing Downpipe. Tips?
does the test pipe take the cat out?
Old Jul 13, 2007 | 11:39 AM
CLX's Avatar
CLX
Zombie Defense Force
Yes, test pipe is for cat deletion
Old Jul 13, 2007 | 04:54 PM
Boostfed13's Avatar
Soak every nut and bolt with WD40 the night before you do the install. Remove the passenger front wheel and the CV axle heat shield to access cat to DP bolts. Trick on of your friends into helping you. Have Band Aid's ready for you knuckles and some cold beers for when you get done enjoy.
Old Jul 13, 2007 | 05:22 PM
chaos92287's Avatar
soak all the nuts with pb blaster (works better than wd40) and prepare to curse a lot. the tp/dp bolts are a biatch to remove. best way i found was to get them from underneath the car with a socket-8" extender-and a flex joint at the end. its hard to generate enough torque to get the bolts loose tho (hence the reason for the pb blaster)
Old Jul 13, 2007 | 06:21 PM
Slowb5's Avatar
its a hellish experience...prepare for the worst. but its do-able.
Old Jul 13, 2007 | 06:33 PM
96audia4's Avatar
Since my cat/dp bolts were completely rusted, I found it easier to disconnect the downpipe/cat from the rest of the exhaust and then mavuever down it to where I could reach the cat/dp bolts better. I also had to use a grinder b/c the bolts just would not budge.
Old Jul 13, 2007 | 06:40 PM
Amze's Avatar
Good luck..
I'd rather pay a dude like 20 bucks at some grudge shop to do the dirty work... haha
Seems like a huge pain
Old Jul 13, 2007 | 07:57 PM
aRIf's Avatar
best tip i can give you is let someone else do it. it's pita to take cat out.
Good luck if you're going to do it becuase you'll need it a lot
KSaudiS8
Aug 14, 2015 09:27 AM
mattrazzo
Feb 20, 2011 03:44 PM
KingJames
Mar 23, 2009 03:16 PM
kwik_shift
Feb 26, 2008 04:05 PM
Sp33d07
Mar 7, 2007 03:46 PM
