Interior Neons
Old Mar 30, 2007 | 11:49 PM
bhunt17's Avatar
Default Interior Neons
So im thinking of adding some interior neon accent lights to my 96 A4but i want to hardwire them to come on with a switch, does any one know any good DIY sites that could help me with this? Thanks.
Old Mar 31, 2007 | 12:31 AM
L.E.O.'s Avatar
Default RE: Interior Neons
I don't know of any interior neon specific DIYs but its fairly simple and easy to do first thing you'd need to figure out is how many volts your neons require? Next how many neons are you installing and where? Also you're going to want to wire the neons in parallel. Hopefully you know and understand this info and can tell us more so we can help.
I don't know how new you are to this kind of stuff but just to be safe here's a list of things you'll probably need:
-12 gauge wire (depending on watts/volts this is probably sufficient)
-wire strippers
-electrical tape
-zip ties
-mounting brackets/screws for neons
-bits and tools to for any interior car parts you'll need to remove
-soldering iron and solder
-toggle switch
Also remember before starting anything to do with wiring/electrical work to disconnect the negative battery terminal!
ptatohed
Mar 26, 2011 06:06 PM
99audia4b5
Feb 10, 2009 05:35 AM
chaos92287
Apr 24, 2007 01:06 AM
ETEAMRACING.COM
Mar 23, 2006 05:34 PM
S4Poor14
Oct 17, 2005 02:08 AM
