Junk OEM Wheel Bearings
Old Mar 30, 2006 | 01:43 PM
dj10's Avatar
Default Junk OEM Wheel Bearings
Does anyone know of a better replacement for these junk oem rear wheel bearings for a A4 1.8 Turbo 2000? Replacing wheel bearings @ every 30K is not a natural act.
Thanks
dj
Old Mar 30, 2006 | 01:45 PM
BFlan2001's Avatar
Default RE: Junk OEM Wheel Bearings
where'd you get yours from? i wouldn't recommend ebay for something like this...ecstuning is probably your best bet
Old Mar 30, 2006 | 02:01 PM
dj10's Avatar
I would never buy a wheel bearing on ebay. We get these bearing that are OEM from Worldpac and the bearing are professionally installed. Audi wheel bearings are destroyed in 30k. What is bad, this is my wife's car and she doesn't drive it hard at all, like I would if it were mine.
Old Mar 30, 2006 | 02:08 PM
BFlan2001's Avatar
are you sure they're OEM? audi wheel bearings are a common issue but every 30k is excessive. i'm at 150k miles and i'm on all original wheel bearings.
Old Mar 30, 2006 | 02:17 PM
Russ03A4's Avatar
I've got 122,000 on my original bearings.
I'd be real suspicious of the source or the install.
Old Mar 30, 2006 | 02:18 PM
dj10's Avatar
Yea, I checked and the wheel bearings are OEM. I also checked with a Audi dealer and they are having the same problems with some A4's. It's weird that some cars like yours can go 150k on the same wheel bearing and a lot of them are getting replaced @ 30k. Sime I'm one of the one's having to replace them at 30k, I'm not too happy, it does get expensive.
Thanks
Old Mar 30, 2006 | 02:20 PM
brrman's Avatar
I would expect you have a defect in your hub(s).
Old Mar 30, 2006 | 02:49 PM
dj10's Avatar
ORIGINAL: brrman
If this is the case, there are a lot of Audi A4's with defective hubs around. I bet I've seen at least a dozen and like I said the Dealers in the area are seeing a lot of them also.
Thrices_own
May 1, 2013 10:18 AM
A4 2000
May 31, 2010 09:23 PM
mcarpen89
Jul 8, 2009 11:31 AM
ocadam
B7 Models
Sep 26, 2008 06:37 AM
mhellman
Jul 16, 2008 09:27 PM
