Just bought car with deployed airbag
Old Feb 2, 2008 | 12:31 PM
99A4NOW's Avatar
Default RE: Just bought car with deployed airbag
ORIGINAL: TheBat
I dont mess with airbags and I dont like them.
Just a couple things to think about... replacing the airbags might be required by law in your state, so you might want to check into that. If it's not required then you may be able to get an upolstery shop to make you some "dummy" airbag covers. And they call them "dummy" for a reason. You'll learn to love an airbag when it saves your life someday.
Old Feb 2, 2008 | 12:40 PM
TheBat's Avatar
Well ill probably end up putting one in it. Just no other option really. Aftermarket sucks. Its probably also the cheapest thing to do. Then getting the airbag code cleared.......
Old Feb 2, 2008 | 01:18 PM
MrFlippant's Avatar
How to replace passenger side air bag in a B5 A4:
https://www.audiforums.com/m_757398/tm.htm
Old Feb 2, 2008 | 02:18 PM
TheBat's Avatar
Thanks guy, if it werent for forums like this one, this job would not go so smoothly. Sorry for getting on your *** like that snipe. Im currently ripping the front end apart, looks like im going to disable the headlight washers. They are all busted up and I wont miss them. Found the wiper lever, nothing a little JB Weld wont fix. Tried to download the check engine light, but no codes came up. I didnt run the car but shouldnt have to. Maybe it was just the airbag code and my scangauge wont pick it up.
Old Feb 2, 2008 | 06:33 PM
CIA's Avatar
CIA
no problem, i made an assumption you were a kid...my bad.
For the airbag cables. Its supposed to have a plug somewhere, if not under the airbag itself, check under the steering column. Usually the airbags are plug and play. Just find the plug.
If you are kind enough, please take pictures during your process of replacing that parts and the job you do to the car, someday someone will maybe need them
Good luck and keep us informed
Old Feb 2, 2008 | 07:49 PM
01AudiA4's Avatar
Insted of doing all that with the bag inside the steering wheel. Wouldn't it be better to just replace the whole thing?
I have help build a 718 RWD G35. Fully built motor twin turbos...
And a 417RWD 350z. Just turbos and clutch.
Old Feb 2, 2008 | 08:09 PM
TheBat's Avatar
The airbag is extremely easy to take off. Just two screws on the back side of the wheel. I tried putting some pics on, but they didnt show up. I clicked upload and it said upload successful, but nothing. What did I do wrong? It was a jpeg.
Old Feb 2, 2008 | 08:12 PM
  #18
TheBat's Avatar
Trying pic again.....
Old Feb 2, 2008 | 09:01 PM
  #19
Rhinop21's Avatar
Host them on a website like photobucket. When you upload them just copy the image code and paste in a post. Then change the [IMG] to [IMG]
Old Feb 3, 2008 | 11:48 AM
  #20
TheBat's Avatar
What a pain
http://s266.photobucket.com/albums/i...t=DSCF0996.jpg
http://s266.photobucket.com/albums/i...DSCF0995-1.jpg
http://s266.photobucket.com/albums/i...t=DSCF0998.jpg
http://s266.photobucket.com/albums/i...t=DSCF0997.jpg
The two bumper mounts are tweaked, should be able to press them back close. I wont be putting a condenser back in so that will give me some extra clearance for the bumper if they dont get pulled out far enough.
A whole bunch of busted up plastic was behind there and tangled in the belts. Guy said he replaced the timing belts 40,000 miles ago, so they should be fine for another 2 years. The one showing with the cover ripped off was slightly loose, is that normal? Do I need to put a cover back on it? I see some cars without them. The car wont be going down any messy roads. I priced the parts, cheapest ive found are on ebay so far, havent gotten a hold of the junkyards that have audis, and im still only looking at about 650 bucks. Not too bad.
bSkogheim
Jun 1, 2015 10:08 PM
pologoped2
Jul 28, 2013 05:47 PM
Sunilk
Aug 25, 2012 08:19 AM
Niclipse
Apr 11, 2011 05:29 AM
crega001
Jun 14, 2006 08:28 PM
