Just want to double check...
Old Oct 14, 2006 | 09:31 PM
theflash's Avatar
Default Just want to double check...
Hi all, new member here and after searching through many posts I have 2 questions:
1. All the spark plug threads I can find are in regards to the 1.8t. Is it recommened to go for the copper plugs for the 2.8 also, or is this a 1.8t upgrade only?
2. Also, with regards to the two cats in the 2.8 30v, is there another safe option to replacing them with oem, or will eliminator pipe or high flow cats work without throwing a code? Anyone have success with either?
Thanks for reading, and any help.
Old Oct 14, 2006 | 09:35 PM
BadLuckAudi's Avatar
Default RE: Just want to double check...
as for plugs Id just use the OEM ones, and the cats you can replace them with high flow ones and probably pass emissions or get rid of them and probably not pass
Old Oct 14, 2006 | 09:38 PM
theflash's Avatar
Alright, OEM plugs check.
As for cats, I don't have emissions in my province. So no code problems with atleast high flows for sure then?
Basically, I'm getting rattling and some popping on decel so I'm thinking I've got some nice clogging action going on. So, I'm looking into getting some custom exhaust bent etc, so naturally I want to know what I can actually do.
Thanks.
Old Oct 14, 2006 | 09:50 PM
If you go custom do like high flow cats or no cats, space out the O2 sensors on the rear and do something like true Dual 2.5 ot 2.75 with magnaflow or remus mufflers
Old Oct 14, 2006 | 10:58 PM
theflash's Avatar
Sounds cool. I did see that thread with the true dual magnaflow in the close-together configuration (can't split in the rear because of spare tire well right?)... which is pretty much what I want to do.
Thanks a lot for you help.
Old Oct 14, 2006 | 11:07 PM
umm i dunno for sure but i think you could probably fid a way to do it however you want
ericp1.8T
Nov 14, 2010 08:14 PM
jophish
Apr 13, 2010 12:18 AM
ImTheDevil
Oct 10, 2009 01:58 AM
chefro
Jul 16, 2009 09:55 AM
MagicHobo
Nov 12, 2008 05:26 PM
