K&N intake
Old Nov 29, 2006 | 11:35 PM
icrasheda90's Avatar
Default K&N intake
I was looking at the intake from evo but i just noticed on k&n's web site they have an intake for my 97 a4 1.8t for like 100 bucks is it any good i really dont want to spend 300 hundred on an intake. http://www.knfilters.com/search/prod...x?Prod=57-0282
Old Nov 30, 2006 | 01:07 AM
AudiTurbo's Avatar
Default RE: K&N intake
Just do a k&n drop in filter....you will be fine.
Old Nov 30, 2006 | 11:01 AM
smokeU's Avatar
yeah the stock intake is pretty good if you go open element your risking major heat soakage.
Old Nov 30, 2006 | 01:05 PM
acetrebo's Avatar
Old Nov 30, 2006 | 01:22 PM
scotia4444's Avatar
the only prblem with k&n filters are that they filter the bigger stuff good but the little stuff not so good
Old Nov 30, 2006 | 01:38 PM
smokeU's Avatar
well if you charge them properly then anything small will get stuck to the oil on the filter surface. if not then you are right.
Old Nov 30, 2006 | 02:44 PM
scotia4444's Avatar
This information is taken directly from my school material
Oiled gauze - Exellent airflow capacity and average cleanability, very good at filtering large particles, fair at filtering small particles.
Due to this filter design's high popularity, it is available for many OEM applications through a large number of manufacturers
Old Nov 30, 2006 | 03:37 PM
socal_A4's Avatar
also if you charge it too much and put too much oil on it say good bye to your maf
Old Nov 30, 2006 | 03:48 PM
scotia4444's Avatar
ORIGINAL: socal_A4
or if you dont let it fully dry and install the filter then drive
Old Nov 30, 2006 | 10:36 PM
the only problem is i want an intake mainly so i can hear something coming from under the hood and i dont want to butcher the air box or spend 300 dollars im not looking to race this thing is the K&N intake really gona be hurting that bad from the heat i mean you use your stock heat shield theres really not alot more to the evoms
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
