K04/PC-16 Another Problem/Question
Old Oct 1, 2007 | 11:31 PM
  #171
The Bishop's Avatar
Default RE: I AM GOING K04 FOR REAL THIS TIME!!!!
The picture that akielbposted is how I am running mine, and it runs really smooth and cool. I just ran the mbc without the n75 for a while to try it out and the engine ran hotter. not really sure why. It was also more surgey.
Old Oct 1, 2007 | 11:35 PM
  #172
onepoint8tee's Avatar
Yeah I wouldnt bypass the N75 with a mbc unless its with a bleeder/gated controller, like we have.
Old Oct 2, 2007 | 12:19 AM
  #173
FASTER's Avatar
Tech Slut
is it me or did the pc16 0-60 vid take 10 seconds... i really think i counted 10 seconds on that but i only played it once...
Old Oct 2, 2007 | 12:26 AM
  #174
ORIGINAL: FasterA4ThanUrs
Yeah it seems way off to me too, but like he said, he had 3 dead bodies in the trunk.
Old Oct 2, 2007 | 01:41 AM
  #175
Audi_Skydiver's Avatar
LOL, yeah it is 9 secs actually. And yes I was way over weighted. I am going to go out and try again sometime soon. What should I be able to get w/the tip tranny?
josh
Old Oct 2, 2007 | 03:11 PM
  #176
kolan67's Avatar
are you ready for the gt28rs now? ARE YOU?
*becomes power hungry*
Old Oct 2, 2007 | 03:49 PM
  #177
LOL, no, not yet. My next bug upgrade is going to be an S4!
Josh
Old Oct 6, 2007 | 01:55 AM
  #178
Ok, another problem that I am getting now...
Almost every time I try to start my car now when it's cold it won't start unless I press the gas pedal down. And the boost thing is getting annoying to. I am going to switch to the N75 valve tomorrow and see if that fixes it. Also how do you tell if the spark is being blown out by the boost? I have my plugs gapped to .030. Would that cause problems? Thanks. i really want to get my car running really well!
josh
Old Oct 6, 2007 | 03:48 AM
  #179
khj677turbo's Avatar
Josh, your dv might be causing your jump in boost. I had an extra vf engineering one laying around that i put in for my hyperboost, and the car would spike and also would just jump to full boost often when i intended it not to. Im running the race n75 and it seems to do the job, when i go half throttle you can hear a loud hissing when the valve is trying to regulate the boost. It holds pretty good at 10 to 15 as i want.
By the way, seems that my thermostat sensor is the obvious choice for my misfires, running rich and such, hopefully the next time i go home i can do my much needed timing belt, change the sensor and hopefully have a fully working setup ( for the first time!)
As for the startup i cant really help you there, could be a coding thing? Sometimes my cruise control wont work right away, so maybe theres a small glitch in the programming. Dunno what to tell you.
Old Oct 6, 2007 | 03:51 AM
  #180
Thats kind of what I thought to. But I am not sure. Would it be that the spring in there is to soft? Maybe put the next one in there? I am going to try the N75 thing tomorrow to see if that helps. It's really annoying trying to pass someone and sometimes just not having the power. Sort of scary to!
Hopefully you get your setup running to!
Josh
