Key Programming for 1999 Audi A4
Old Feb 23, 2007 | 12:47 PM
malubeast21's Avatar
Default Key Programming for 1999 Audi A4
I have tried so many key programming instructions using two keys. And none of them has worked. I have a 1999 Audi A4 Quattro. If anybody know how to program the keys, can somebody give me the instructions. That will be really helpful. Thanks!
Old Feb 23, 2007 | 05:05 PM
ryansonfire's Avatar
Default RE: Key Programming for 1999 Audi A4
i believe vag-com can do it. go to ross-tech.com.
Old Feb 23, 2007 | 05:11 PM
xel04's Avatar
1) Take one key and put it in the ignition and turn the ignition ON. (The one you want to program)
2) Close and lock the driver's door with the second key (while the ignition remains on).
3) Take the first remote and press the "UNLOCK" button ONCE only - alarm will 'beep' but door will remain locked.
4) With the key, unlock and lock the door again.
5) Test the remote by pressing the "UNLOCK" button again - door should unlock.
6) Open the door and turn ignition off and back on again using the first key.
worked for me.
techbod's Avatar
its been covered so the search is a good option
Old Feb 24, 2007 | 01:42 PM
kuma's Avatar
Hi,
Can someone tell me if I can do key programming by myself for 2003 A4?
I just dont wanna to spend an extra 100 bucks on dealership,
Thank you,
Old Feb 24, 2007 | 11:29 PM
xel04's Avatar
yes, read my post and SEARCH! (on the forums)
Old Feb 28, 2007 | 02:10 PM
kuma's Avatar
ORIGINAL: xel04
I tried the method you posted,
but it did not work,
I have no idea what to do,
Kuma
Old Feb 28, 2007 | 02:19 PM
techbod's Avatar
[IMG]local://upfiles/12092/9D3111C3DF5F489D97B41CA1BEBC4D92.jpg[/IMG]
[IMG]local://upfiles/12092/EFDBD68F97E444AAB410FB916883E966.jpg[/IMG]
Old Feb 28, 2007 | 09:11 PM
piloturco's Avatar
you might have a problem man with your car man, cuz i bought a new key on ebay and did the exact same things written here, it worked at that moment, i have a 98.5 1.8tqm... or 99 models might be different... keep on trying...
Old Apr 26, 2014 | 03:04 PM
pradipsahu's Avatar
Default Worked for me
I just changed the battery on my remote and luckily found these instructions. They worked fine for my 99 1.8T.
heatON19
Nov 7, 2012 11:11 AM
myaudia6
Jul 4, 2008 03:47 PM
moonstruck
May 31, 2008 02:22 PM
mjvss21
Nov 22, 2005 10:34 PM
fortunato74
Feb 27, 2005 11:11 AM
