Knocking comming from frount of car HELP
Old Aug 10, 2006 | 12:40 PM
BaconBait's Avatar
Default RE: Knocking comming from frount of car
Is it loud? Can you hear it with the radio on? Is there anything loose under the hood?
Old Aug 10, 2006 | 02:34 PM
acetrebo's Avatar
How is your steering? Is it really tight or a little loose?
I am thinking worn tie-rod ends or a control arm if thats the case, because that can make a "clunking" sound from the front end. Other than that, these guys may be on track with a clutch/tranny issue.
It doesn't sound engine related.
Old Aug 10, 2006 | 02:40 PM
Mike@PureMS's Avatar
Sounds like it could be the brake pads. Some brake pads can shift ever so slightly within the brake carrier. This can happen when you start moving or even change directions. You can test this by lightly hold the brake pedal when you start moving, and see if the problem goes away.
If this is the problem, unfortunately there isn't much to fix it other than try some different brake pads.
Old Aug 11, 2006 | 01:20 AM
vlad666's Avatar
Default RE: Knocking comming from frount of car HELP
Im new but, my 2002 A4 is getting the same noise. Two dealerships and 3 days of warranty searching w/ no results...... From personal experience it is the throw out bearing. But that's me. Any help would be great
[IMG]local://upfiles/22010/ACFBC6A8E6AE422883D7EA66988A046A.jpg[/IMG]
Old Aug 15, 2006 | 05:14 AM
TurboQuattroPwr's Avatar
Well in my situation I can hear the noise at a complete stop. Like I said previously, it sounds like a dripping noise from the right front of the car.
drogce
Aug 27, 2009 09:07 PM
millenia
Oct 26, 2007 08:27 PM
AudiMD
Sep 6, 2007 11:30 PM
Colin519
Nov 4, 2006 11:11 PM
OWDI
Apr 20, 2005 02:09 AM
