ko4, quick quest.
Old Dec 23, 2006 | 04:00 AM
khj677turbo's Avatar
Default ko4, quick quest.
The 00-01 a4 ko4 kit from AWE doesnt come with upgraded injectors, are they necessary, or is that just a waste of money to get on the side?
Old Dec 23, 2006 | 04:18 AM
Lazer Viking's Avatar
Default RE: ko4, quick quest.
not nessecary
Old Dec 28, 2006 | 01:02 PM
Wrench's Avatar
Y not LV?
Old Dec 28, 2006 | 01:10 PM
NuYorka103185's Avatar
not necissary but a a good upgrade
Old Dec 28, 2006 | 01:51 PM
new2me's Avatar
I thought that you would run lean if dont upgrade the injectors and fpr.
Old Dec 28, 2006 | 04:32 PM
SAudi's Avatar
depends on the boost levels and injector delivery capacity. not neccesayr under correct boost levels and optimum fuel delivery.
Old Dec 28, 2006 | 04:41 PM
onepoint8tee's Avatar
Wow.... It depends on what tuning (chip)you get. There is a basic k04 file which doesnt require anything but a 5 barfpr, then there are aggressive k04 files (pc16 for 97-99.5, j31 for 00, and hammer for 01) which require injectors, afpr, fmic, and the TT maf housingi believe. Of course all of them require the use of a high flow exhuast.
Old Dec 28, 2006 | 04:52 PM
FASTER's Avatar
Tech Slut
cant do injectors on the k04 without a fmic. by the way that kit comes with a fpr.
Old Dec 28, 2006 | 05:00 PM
ORIGINAL: FasterA4ThanUrs
What additional mods you can do with the k04 turbo all depends on the tuning/flash/chip. fmic, injectors and the rest go hand in hand with the more aggressive k04 flash whether it be pc16, j31, or the hammer file - depending on what yr you have.
Old Dec 28, 2006 | 07:15 PM
swift_A4's Avatar
w/ out a fmic you would heat soak with first spool of the k04 w/ bigger injectors and that much boost
zombi4u
B7 Models
Dec 13, 2010 03:26 PM
beg330
Dec 31, 2008 08:28 AM
oettinger1919
Nov 17, 2007 09:51 PM
G
Aug 3, 2006 03:44 AM
ONEUP
Jan 30, 2004 03:19 AM
