Lost Power and it sounds like suction
Old May 4, 2005 | 07:16 PM
hypnotiks's Avatar
Default Lost Power and it sounds like suction
i Have 2000 A4 1.8T Tiptronic Quattro, MTM chip, 710n DV, I start with power when it kicks into 2nd gear you here a suction sound(like if you cover a vaccumm cleaner with your hand) the sound goes for like 2 seconds. and at the same time i loose power.... it feels like the car is holding back or real heavy. and if i press down all the way on the pedal it like catches power right away but it jerks also but then the same happens. any suggestions..???
Old May 4, 2005 | 07:21 PM
TomRitt's Avatar
Default RE: Lost Power and it sounds like suction
Something boost related, maybe a ripped charge pipe, or bad dv?
Old May 4, 2005 | 07:23 PM
audiboy1618's Avatar
Im with tom, def boost related, maybe a vacuum leak.
Old May 4, 2005 | 07:46 PM
hypnotiks's Avatar
I am going to change the 710N DV again ...but this time i will get the Forge Brand.
Old May 4, 2005 | 07:52 PM
jukeit's Avatar
This question is redundan when you say you are losing power, your rpms are dropping correct?
Old May 4, 2005 | 07:58 PM
hypnotiks's Avatar
when i start driving i feel the power....once it goes into the next gear i feel like something is pulling the car back or real heavy......my rpms are still going up but alot slower
ou2mame
Mar 26, 2012 05:59 PM
hyland
Oct 8, 2007 03:39 PM
A4philly
Jun 15, 2007 07:37 PM
adriancdn
Aug 15, 2006 03:49 AM
forcefedaudi
May 12, 2006 06:31 PM
