Lots of questions for newbie!!
Old Oct 17, 2011 | 05:22 PM
flyby76's Avatar
Default Lots of questions for newbie!!
Hi guys and gals, a newbie im afraid so apologise in advance if the following questions are obvious
Have just bought a 96 A4 Avant estate with the 1.8 petrol engine, when viewing the car i tried the heaters (has the elecrtric AC panel) and i heard the fans come on so thought nothing more of it.
After purchasing the car and driving home couldnt get it to blow out any cold air, or any air for that matter, if i move the temp control on the electronic panel I can feel a difference in heat in the air that is slightly wafting through the vents, for about 5 mins i got it to blow air but that was it. At a standstill and with the engine off I can hear the electrics moving motors etc when i select the different settings ie footwell, window etc but cant get it to blow air, is this a simple fix like a fuse or relay or do I need a new heater box or fan?!
The other problem I have found is the passenger electric window dosent work, no noises, clicks, grinds or smoke! Just dosent work on either driver switch or passenger switch, any ideas?!
And finally driving in the dark last night have noticed that the bottom half of the speedometer dial and the needle is not lit and theerefore finding it very hard to see what speed im doing, is fitting a new bulb an easy fix or does the whole dash have to come out?!
Sorry for the essay and the multitude of questions but any help or advice would be greatly apreciated!!
Cheers Dan
synesthesia
May 30, 2010 09:32 AM
HuntersA42.8
Mar 14, 2010 11:47 AM
Black_97 A4
Mar 12, 2007 08:00 PM
SteveOfTheNorth
Sep 10, 2006 07:44 AM
Riddler
Jul 8, 2005 12:05 PM
