maintenence
Old Mar 4, 2005 | 12:47 AM
thintzen's Avatar
Default maintenence
whats the dealer procedure for maintenence on a 98 a4 1.8t with 88k on it?
and the prices it may run me
i wanna make sure i can do some of the stuff myself and save some money
and do i need ot flush my tranny oil?
Old Mar 4, 2005 | 12:49 AM
Jestnomen's Avatar
6th Gear
Default RE: maintenence
Has the timing belt/water pump been changed? Here are some things to think about:
Change engine oil
Change engine oil filter
Replace air filter element
Replace spark plugs
Replace accessory drive belt
Replace timing belt
Replace timing belt tensioner pulley
Replace timing belt idle roller
Replace water pump
Replace coolant thermostat
Change engine coolant
Change brake fluid
Change power steering fluid
Replace climate control dust and pollen filter
Check transmission fluid level
Check electrolyte level of battery
Check brake pad and rotor thickness
Check CV boots for cracks
Check windshield washer fluid level
Check air pressure in spare tire
Inspect engine for leaks
Clean guide rails of sliding roof and lubricate with silicone spray
Check tension and condition of timing belt
Check dust seals on ball joints and tie rod ends
Check water drain valve in plenum chamber
Check engine idle speed (not for models with ODB)
Check OnBoard Diagnostics (OBD) fault memory and clear if necessary
Doose's Avatar
Have you done the timing belt and water pump yet?
Old Mar 4, 2005 | 12:52 AM
thintzen's Avatar
i was told i have a timing chain..i dont know
i have a 1998.5 1.8t
Old Mar 4, 2005 | 01:01 AM
Jestnomen's Avatar
6th Gear
ack, no it's a belt trust me. It should be your first priority right now. After 60-70k miles, you are driving at your own risk.
Old Mar 4, 2005 | 01:02 AM
CRAZYHAWK's Avatar
You have a belt.
Old Mar 4, 2005 | 01:48 AM
BFlan's Avatar
if your belt goes...your engine goes. make sure it's been replaced.
cdmx
Mar 17, 2007 10:28 PM
enjoey
Dec 22, 2006 08:36 PM
TXA41.8
Nov 14, 2006 02:16 PM
AML 225
Dec 9, 2005 03:16 PM
thintzen
Nov 19, 2004 09:27 AM
