MAP & MAF Bad
Old Feb 14, 2007 | 07:57 PM
  #31
MissionCtrl's Avatar
Default RE: MAP & MAF Bad
hmmm...mayhaps this explains why my car is only boosting to 5psi...might have to do some cleaning tonight and see if it helps. no cels tho.
Old Feb 14, 2007 | 10:41 PM
  #32
onepoint8tee's Avatar
5-7psi is normal for stock on a 97-00 with spikes to 10.
Old Feb 14, 2007 | 11:13 PM
  #33
lol yeah but i spike to 5
Old Feb 14, 2007 | 11:14 PM
  #34
not a leak either. hook up a mbc and she'll run 8-10psi all day long. i think my n75 is havin a crack attack...
Old Feb 14, 2007 | 11:16 PM
  #35
Jeff's Avatar
Zombie Defense Force
ya that will work. mbc are good if you keep the boost at what you need to be running not more or less
Old Feb 14, 2007 | 11:19 PM
  #36
yeah no worries i've got no plans on running lean and blowin sh*t up. don't actually have a mbc hooked up yet, but it will be once i find a testpipe and throw in my ko4. what should i set my boost at for a pc-16 file? 18-20psi???
  #37
hmm well if you can hold 8-10psi with the mbc then youre probably right about the n75 being a cracked out. Just dont crank it up too much cuz limp mode isnt going to save your engine from leaning out too much since youre pre 2000.
Old Feb 14, 2007 | 11:25 PM
  #38
haha no i'm not going to bump it up, its my daily driver and the only reason i'm using a mbc is because it was easier and cheaper to get than a n75. plus i figured it would help with spiking once i get my pc-16 file in.
Old Feb 14, 2007 | 11:47 PM
  #39
Jeff's Avatar
what kind of mbc are you getting?
Old Feb 15, 2007 | 12:47 AM
  #40
turbo kraut's Avatar
Tech Guru
dude, your not boosting, if what the audi mechanic says is right, because your thrust sensor is bad
it doesn't exactly put you in limp, it just won't allow your car to boost, it could be the n75, but a new one is like 35 bucks right?
if you need a new thrust sensor, go to the vw dealer, they are cheaper than audi
all in all, a new maf and thrust cost me 254, both brand new, a new maf at audi was like 300, and the thrust was 237 i think, so i got both just above what a thrust would of cost me
see if there is one in a local junk yard
