MBC Question:
Old Mar 8, 2007 | 04:36 PM
AudiCross's Avatar
Default MBC Question:
Okay. i have been wondering about my boost suddenly jumping to 20 ish then instantly dropping to 15 ish. I talked to the guys at 2Bennett Audimotive and they said it is my computer seeing that the boost is too high and telling it to drop, which is normal. (these are 1.1bar chips which is around 16 psi)
I was wondering, could i put in a manual boost controller and allot it to run to full boost?
Old Mar 8, 2007 | 04:48 PM
MissionCtrl's Avatar
Default RE: MBC Question:
if you put it in your car and set it to say 16/17 psi you would reduce spiking. just be careful you don't set it too high
Old Mar 8, 2007 | 04:49 PM
oh1a4's Avatar
there is only one solution that does it right:
http://www.modshack.info/bm.htm[/b]
Old Mar 8, 2007 | 05:23 PM
BadLuckAudi's Avatar
ummm no..... there is more than one right way to do it, but even better that your thing there is just a different N75 valve
ORIGINAL: oh1a4
Old Mar 8, 2007 | 05:59 PM
AudiCross's Avatar
but with a different n75 vlve, the computer would still see the spike and make it go byebye. unless im compleetly wrong on how an n75 valve works...
Old Mar 9, 2007 | 04:35 AM
AudiCross's Avatar
bump anyone?
Old Mar 10, 2007 | 04:35 PM
AudiCross's Avatar
yoohoo. i feel lonley here
Old Mar 10, 2007 | 04:50 PM
onepoint8tee's Avatar
The N75 reduces spiking. I may get a 1 or 2 psi spike with my H valve. I hold 18-20 psi depending on the weather. When I gun it, I usually see maybe 21 psi and then it levels out to 19-20psi.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
