Misfire and running rich
Old Sep 10, 2007 | 10:09 PM
natedog266's Avatar
Default Misfire and running rich
I have a 1996 A4 2.8. Last week I was driving home, then all of a sudden the car started runningreally wierd and vibrating and the check engine light started flashing. As soon as i got it off the road I checked the codes, and it detected a misfire in cylinders1 and 6 (both plug into the same coil). It also said that both bank1and 2 were running rich. Other forums say to switch the coil packs around to see if the misfire changes cylendars, but the three coils go into two wiring harnesses and don't unplug anywhere before that. Is it possible to switch those around on my model? I am planning on replacingall threecoil packs (because you have to buy them all together the way I understand it) to see if that fixes the problem.
If anyone has any suggestionsI would appriceate it, or let me know if you have had any simmilar problems. Thanks!
Old Sep 10, 2007 | 10:33 PM
ImTheDevil's Avatar
Default RE: Misfire and running rich
I'd think you would be able to swap the coil packs around without too much trouble, but I haven't messed with that on my own car so I can't say for sure. However, as for replacing them, remember to check Classifieds here - there are a few guys parting out cars, and I'd bet you can get a single coil pack from one of them and save yourself a pile of money.
Old Sep 10, 2007 | 10:39 PM
natedog266's Avatar
Ya, that sounds nice, but I need it ASAP because I'm leavin for college at the end of the week. I'll check them out though. Thanks!!
Old Sep 11, 2007 | 09:41 AM
CRAZYHAWK's Avatar
www.ecstuning.com
www.rockauto.com
are good for parts.
Air filter and spark plugs may need changing.
incrementalg
Mar 23, 2008 08:02 PM
discontained
Jun 10, 2007 11:12 PM
keko2004
Jan 12, 2007 04:53 PM
johnstef
Dec 24, 2006 11:29 AM
SuperS4
Jul 18, 2006 12:34 AM
