Motor mounts dead?
Old Nov 25, 2006 | 02:01 AM
m5racer's Avatar
Default Motor mounts dead?
How do i know if i need new motor mounts? when ever release the clutch after changing a gear i get a little jerky throw from the engine...its really had to have a really smooth switch is it my motor mounts?
Old Nov 25, 2006 | 06:17 AM
m5racer's Avatar
Default RE: Motor mounts dead?
help
Old Nov 25, 2006 | 11:57 AM
raimond's Avatar
I think mounts are the problem. See the post:
What are some symptoms of a bad motor/transmission mount?
Old Nov 25, 2006 | 04:51 PM
m5racer's Avatar
thanks so much for ur help
Old Nov 25, 2006 | 08:34 PM
Mike@PureMS's Avatar
When motor mounts fail, they leak a dark purple fluid. Simply remove your belly pan, and inspect the mounts. You'll notice right away if they've gone bad.
We carry an assortment of mounts including some nice upgraded models.
raimond's Avatar
Also if you have changed clutch or it is near dead you may also experience some jerky throw (more common situation is when the clutch slips). Usually it happens when you start driving releasing clutch.
Kisco12
B7 Models
Jan 3, 2014 11:05 PM
B7Night
B7 Models
13
Nov 11, 2013 09:18 PM
silveraudib6
Oct 9, 2009 03:29 AM
cincyTT
Dec 5, 2007 10:11 AM
00Azul
May 11, 2006 03:03 PM
