My CEL codes... what do they mean?
Old Sep 28, 2005 | 08:21 PM
Karl's Avatar
Default My CEL codes... what do they mean?
Hi everyone.. long time listener first time caller...
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8A0 959 655 D
Component and/or Version: Airbag V AUDI D00
Software Coding: 00127
Work Shop Code: WSC 63342
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High – Intermittent
Control Module Part Number: 8D0 906 266
Component and/or Version: 2,8l V6/2V MPI OBD2 D01
Software Coding: 01201
Work Shop Code: WSC 06335
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 68-00 - Cylinder 1
Control Module Part Number: 8D0 820 043 F
Component and/or Version: A4-KLIMAVOLLAUTOMAT_D64
Software Coding: 00062
Work Shop Code: WSC 00000
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Old Sep 29, 2005 | 03:13 AM
Karl's Avatar
Default RE: My CEL codes... what do they mean?
bump.....
Old Sep 29, 2005 | 10:21 AM
dafrazi's Avatar
Try the ross-tech forum or the VAG-COM forum on VWVortex.com. They have the most infomation when it comes to this stuff.
Old Sep 29, 2005 | 07:49 PM
Jestnomen's Avatar
6th Gear
- Clear the airbag codes, and see if they come back.
- Could have a blocked EGR passage. Might want to have it cleaned or do it yourself.
- I had the same fault code for the fuel sender. I wrote a tutorial for changing it. It is located in the how-to section on this site.
- Are you having any problems with your climate control? If not then leave it alone. AFAIK, repairs to the flap motor require a lot of dash removal and time.
Old Sep 29, 2005 | 08:52 PM
Karl's Avatar
ORIGINAL: Jestnomen
Cleared the airbag code a couple times it comes back right away.. Think its the sensor in the front bumper..
thanks.. wasnt sure if that was the same thing as what you were referring to in that tutorial.. now that i know that will make life a lot easier..
climate control seems to work.. so i will leave that alone.. thanks Jest!
Old Sep 29, 2005 | 09:19 PM
Jestnomen's Avatar
6th Gear
The ignitor is what lights the propellent in the airbag. Doesn't sound like the sensor in the bumper. You might have a loose connection in there. I've read that if there are airbag faults the airbag system will be diasbled. Not sure if this is true or not though.
Old Sep 29, 2005 | 09:21 PM
Karl's Avatar
the reason im thinking its in the bumper.. is because this started happening when I pulled the bumper off to do the snub mount.. hmmm
Old Sep 30, 2005 | 08:13 PM
hoonee46's Avatar
I've had the EGR code before, and the vacuum hose that led to EGR valve was gone...
it was gunked up and snapped off... I just had to replace that hose and the CEL was gone...
so of course, the hissing from the vac-leak went away, replace by a subtle but s/c-like whine....
Old Sep 30, 2005 | 08:55 PM
Karl's Avatar
Honee.. do you have a pic of where the EGR valve is ?
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
