My CEL codes... what do they mean?
Hi everyone.. long time listener first time caller...
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8A0 959 655 D
Component and/or Version: Airbag V AUDI D00
Software Coding: 00127
Work Shop Code: WSC 63342
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High – Intermittent
Control Module Part Number: 8D0 906 266
Component and/or Version: 2,8l V6/2V MPI OBD2 D01
Software Coding: 01201
Work Shop Code: WSC 06335
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 68-00 - Cylinder 1
Control Module Part Number: 8D0 820 043 F
Component and/or Version: A4-KLIMAVOLLAUTOMAT_D64
Software Coding: 00062
Work Shop Code: WSC 00000
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
1 Fault Found:
2 Faults Found:
3 Faults Found:
- Clear the airbag codes, and see if they come back.
- Could have a blocked EGR passage. Might want to have it cleaned or do it yourself.
- I had the same fault code for the fuel sender. I wrote a tutorial for changing it. It is located in the how-to section on this site.
- Are you having any problems with your climate control? If not then leave it alone. AFAIK, repairs to the flap motor require a lot of dash removal and time.
ORIGINAL: Jestnomen
thanks.. wasnt sure if that was the same thing as what you were referring to in that tutorial.. now that i know that will make life a lot easier..
climate control seems to work.. so i will leave that alone.. thanks Jest!
The ignitor is what lights the propellent in the airbag. Doesn't sound like the sensor in the bumper. You might have a loose connection in there. I've read that if there are airbag faults the airbag system will be diasbled. Not sure if this is true or not though.
I've had the EGR code before, and the vacuum hose that led to EGR valve was gone...
it was gunked up and snapped off... I just had to replace that hose and the CEL was gone...
so of course, the hissing from the vac-leak went away, replace by a subtle but s/c-like whine....
